Message 1 of 6
Damaged Fibre Optic Cable
Hi contractors have accidentally damaged the fibre optic cable connecting our broadband. How do I book an engineer? BT diagnosis tool just says they have detected an incident in my area and given estimated fix date/time but I’m not sure anything is actually being done/scheduled for a visit?
5 REPLIES 5
Message 2 of 6
Re: Damaged Fibre Optic Cable
Just report a fault to customer services
0330 1234 150
Message 3 of 6
Doesn’t give you option to talk to anyone straight to bot
Message 4 of 6
Don't know whether it works with BT's bot, but often, if you repeatedly type gobbledegook, you eventually get put through to a human
Message 5 of 6
It used to be if you ignored the options they would just put you through to someone after repeating them a couple of times.
Message 6 of 6
@mrlarner Option 1 then option 4 will get you through to a guide in the faults department.
Neil
