Message 1 of 3
Damaged fibre optic cable
Can any one tell why it takes by openreaxh so long to fix a damaged fibre cable?
the cable was cut nearly 4 weeks ago by Thames water contractors and still nothing has been resolved the service is utter **bleep**.
have been with out internet or phone for nearly a month will be lucky if I have a business left at the end of this.
2 REPLIES 2
Message 2 of 3
Re: Damaged fibre optic cable
As a business user you need to post here.  https://business.forums.bt.com/. This is a residential forum
Message 3 of 3
Are BT your provider ?, this is a BT Consumer forum, Openreach are effectively a separate company …it’s upto your provider to chase their supplier.
