Message 21 of 33
Re: Data rate/line regrade
@Gary1961
did you use the consumer email address or the complaints link.  best option is consumer email address
Message 22 of 33
I used the complaints link, I got a confirmation email confirming the complaint was raised. Looking at the timeline on the complaint it says a call is scheduled for today, but it's still at the 'Your complaint has been raised' stage of the process.
Message 23 of 33
I've had a call from the complaints team, they're going to send an engineer on Saturday. The guy I spoke to (and his colleagues) apparently had never heard of a stuck profile or a DLM reset before. This doesn't fill me with confidence, but I'll see where it goes.
Message 24 of 33
An engineer visit will not fix a stuck banded profile apart from getting the openreach engineering to phone his office and get a DLM reset
You would be better using the consumer email address as that goes to Executive Level complaints and will get you some action
Message 25 of 33
I know, the guy I spoke to didn't have much technical knowledge - he said the engineer might have to go to the exchange to reset it....! (I'm on FTTC) He insisted on sending one on Saturday, so it will make for an interesting conversation. I'll get the tea and biscuits ready!
Unfortunately I'd already started the ball rolling before you told me about the consumer-level option, I was only going on the advice given on here (by someone else).
I must admit I did look up the CEOs email address, but decided to avoid going nuclear just yet. It's crazy that I wasn't offered a call back by someone technical who could have just pressed the right buttons to make it happen!
Message 26 of 33
Just had the engineer call - he hadn't been informed of the problem - just slow speed. Because the speed we are getting is more than the minimum guaranteed speed there's nothing he can do about it. I explained that that speed was obtained when the line was faulty and I even showed him the figures on the router. He didn't attempt to get a line reset.
I am so furious as it was a complete waste of time - all he said was to complain!
Message 27 of 33
thought so engineer not interested.  Just use the consumer email and complain.  you should get reply from Executive level complaints and hopefully some action to reset DLM
Message 28 of 33
To make matters worse I then received an automated email telling me "Your service is working again"!
How do I access the "consumer email" to complain as that hopefully will resolve it?
Many thanks.
Message 29 of 33
use the link in @Lesley_W  message 18
Message 30 of 33
OK thanks for that, I'll try that one later!
