Message 1 of 5
Digital voice.
Dose anyone know if I got the Digital voice service will my broadband cost go up to what it is now or will it stay as it is right now?
4 REPLIES 4
Message 2 of 5
Re: Digital voice.
Hi @Friendly835   Exactly the same. The only thing that changes is the delivery, not the cost. Home phone calling plan costs are also the same.
Message 3 of 5
Re: Digital voice.
If you are being moved to DV from the old PSTN service there should be no cost change.
However, if you currently have broadband without a phone service and are switching to broadband + DV that will require the broadband re-contracting and the phone service will add £5 more.
Take a look at this:
https://www.bt.com/content/dam/bt/storefront/pdfs/BT_PhoneTariff_Residential.pdfhttps://www.bt.com/c...
Message 4 of 5
Re: Digital voice.
If no other changes are made, Digital Voice is exactly the same price as analogue telephony and has no impact on the price of broadband.
Message 5 of 5
Re: Digital voice.
As stated , it depends on what you currently have , broadband without any telephony at all (so no phone number associated with the broadband, no incoming or outgoing calls including 999 calls ) is cheaper than broadband and telephone together , so if you don’t currently have telephony and ask for it to be added expect to pay something for that additional service, if this is just a question about moving to DV telephony from PSTN telephony then there is no change to the price .
