Message 1 of 22
Digital Voice stopped working
Hello,
I was wondering if anyone could help, as I am fairly clueless on this sort of stuff.  We have been on Digital Voice with no problems for a while now, but today I noticed I was getting no dial tone and on checking, the phone line adaptor was flashing red (the hub is upstairs, the adaptor/phones downstairs).  I have tried re-pairing the two devices and moved the adaptor closer to the hub, but just the same - a flashing red light on the adaptor.  Broadband is currently working fine.  Would anyone have any suggestions.  Thanks in advance for any help.
21 REPLIES 21
Message 2 of 22
Re: Digital Voice stopped working
Does the hub manager show your phone number or display 'not configured'
Message 3 of 22
Does the hub itself indicate that it is connected.  That is, does the management home page show your phone number or "service ready"?
Edit:  Ah, Licquorice beat me to it.
Message 4 of 22
Hi
Thank you for replying.  It says 'Not Configured'.
Message 5 of 22
Then you will need to call BT I'm afraid. 0330 1234 150
Message 6 of 22
Okay, thanks again.
Message 7 of 22
Just to check, resetting the hub would be pointless?
Message 8 of 22
Worth a try, but probably won't help.
Message 9 of 22
Thanks again for taking the time to reply - much appreciated.
Message 10 of 22
To update this.  I phoned BT in December, explained the situation and the assistant I spoke to said that he could see an issue, had dealt with something similar the day before, fixed things and everything was back to normal.  Then last week the same thing happened - phone adaptor flashing red, and the hub manager showing that the phone was 'Not configured' .  Contacted BT again (had to do it via text this time as the contact procedure seems to have changed) and as I was waiting the phone adaptor went to the normal colour once again.  The operative told me that resetting the hub would have sorted things, but I don't believe this is true, but I let it go.  Anyway, today the phone line has gone again - broadband is fine, but the phone adaptor is flashing red and the phone 'Not Configured'.  Can anyone give any guidance as to why this would keep happening?  Thanks again for taking the time to read this, and any help that you can give.
