Message 11 of 19
Re: Extremely slow upload
Sorry was at work home on lunch here’s that log
InformationEvent log
This is a list of your Hub settings and current statistics.
Product code:Hub
Serial number:+091301+1936007002
Firmware version:v0.40.00.04147-BT
Firmware updated:Sun Aug 27 20:29:10 2023
Board version:R01
GUI version:1.79 12_06_2022
DSL uptime:1 days,12 Hours33 Mins04 Secs
Data rate:359 Kbps / 16.493 Mbps
Maximum data rate:394 Kbps / 19.578 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:8.0 / 8.8
Line attenuation:12.0 / 31.8
Signal attenuation:7.3 / 34.4
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:1.6 GB Uploaded / 14.9 GB Downloaded
Broadband username:bthomehub@btbroadband
Public Wi-fi status:Activated
2.4 GHz wireless network name:BT-FGA68G
2.4 GHz wireless channel:Smart (Channel6)
5 GHz wireless network name:BT-FGA68G
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:F0:86:20:58:F4:79
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 12 of 19
It’s missing a .com did not let me post it with it in
Message 13 of 19
The higher that expected noise margin in both directions would indicate poor line quality which is causing DLM (Dynamic Line Management) to reduce the connection speed.
Also, your connection time is only showing 1 days,12 Hours33 Mins04 Secs which would indicate the connection dropped recently, unless of course you restarted the home hub, which would make matters worse.
Do you have a phone connected to your line?
If you do, then dial 17070 and select option 2 (Quiet Line Test) and see if you can hear any noise between the announcements.
Message 14 of 19
Unfortunately I don’t have a phone to plug in as I never use the landline it’s only there for the Blocked bond
Message 15 of 19
The low uptime is probably dew to a short power cut
Message 16 of 19
Is there any chance you could get hold of a cheap wired phone, just to do the test, it may even clear the fault by passing current through the line.
Argos do a cheap phone for about £10, or you may find a cheaper one on Amazon.
Message 17 of 19
Ran the nice test and all seems good with that
with no improvement after running it
regards Bill
Message 18 of 19
Any update on this been having problems for months upon months now
Message 19 of 19
Spoiler
This is not getting better it’s getting worse my upload is. Ow sitting at 0.08
