Message 11 of 12
Re: FTTP---Digging up driveway
If your address has been surveyed and then the network built and your address can order FTTP , then this site should show the method .
FWIW , if your address is currently fed by a DIG copper cable , and FTTP is now available then there will have been some civils work done on Openreach’s behalf, either poles or footway ‘Toby box’ or duct caps should be visible just outside the property curtilage
Message 12 of 12
@Dungivenwrote:
I am thinking of ordering the FTTP 500 product but concerned my driveway may need dug up..i have entered my details into the BT checker and get following message
"Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG premises served by 1 Inch duct 100.
FTTP is available and a new ONT may be ordered."
Does this mean my drive may not  be dug up? No idea what" a new ONT" is. I see no evidence of entry point or any external cabling etc but going by a previous post i can assume they would tell me before hand and if the drive did need dug up i could cancel my order without penalty?
As you cannot see your present entry point are you possibly in Northern Ireland?
