Message 41 of 42
Re: FTTP Fibre 900 upload capped
I'd like to request mod help also, I have my ff900 plugged directly into my ps5 which is getting great download speeds however my uploads are fluctuating between 10 -50 most days, and from on minute to the next it varies from one end to the other.
what would you need from me to be able to assist further?
many thanks
Message 42 of 42
Hello @Artannis
This thread has been solved so best you open a fresh one for the help you need.
In the meantime you may want to test a laptop/PC plugged directly in etc and also mention what speedtest you are performing.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
