Message 11 of 15
Re: FTTP Fibre needed in an outbuilding
Thanks v much, to everyone. For a few reasons, I cannot dig to connect. I appreciate it's more costly, but is there any reason I can't simply have, and pay for, a second line? When I spoke to them, BT seemed to NEED a NEW, independent address, which this isn't. It would be very easy (practically and logistically) to add a new cable directly from the telegraph pole into the studio (unlike the house, the studio is close to the road / pole). BT seem to treat my request like it's against the law or rules or something. I want to pay for an extra line - but they're responding to me like I'm the first person that ever asked, and that its impossible.... cos the computer say's no.
Message 12 of 15
When an area is dimensioned, all the ‘dwellings’ that are appropriately registered as a ‘proper’ address are in effect counted and number used to provide the appropriate size of the network for that immediate area , so your problems are two fold , first you would have to get the studio it’s own postal address , ( otherwise it would never appear as an valid address in the systems used to raise an order ) by making it a property liable for council tax etc , then , once the property is registered an order potentially could be raised , provided there was spare capacity at the CBT , capacity is probably OK , but there is a chance of no spare ‘fibres’ at the CBT
As already suggested the most obvious solution is your own Ethernet ‘cable’ between the two points , or even a point to point microwave link , if there is line of sight , and the prospect of providing a cable link is not practical,
FWIW, you don’t need to adhere to the same standard as Openreach would ( putting cables underground at the appropriate depth of cover , reinstatement etc ) so for arguments sake an Ethernet cable laid overground ( possibly in some sort of flexible conduit) between your house and studio would be no one’s responsibility but your own , if it were damaged , tripped over , etc
Message 13 of 15
I'd probably go with a point-to-point link - ubiquity do several.  Depending on what you go for you may need a license, but it's not exorbitantly expensive and is pretty much a formality.  Speeds are generally not earth-shattering, and the equipment definitely adds a little lag so gaming from the studio could be marginal!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Message 14 of 15
Have you considered a 4/5g mobile broadband contract if the signal is good enough at your outbuilding.
Most mobile phone suppliers do them with unlimited data.
Message 15 of 15
Thanks again to everyone...very helpful, and at least I'm better armed now to investigate a workable solution.    Didn't know about mobile broadband (prob clear I'm a luddite), so will have a look.  I'm with BT (and EE for mobile phones), so presumably as good as any.   Appreciate everyone's input..thanks again.
