Message 1 of 2
FTTP Install
  • Hi
I am waiting to get fttp after a blockage was found on some conduits from a manhole supplying my house. The civils team are due to unblock this first so once cleared I'll see if I can pull the existing 2 pair for an easier install. The cable looks to run down a conduit in a wall but it's not clear if this continues in a conduit outside.
If I opt for an install through the outside wall, does the ONT need to be directly connected to the HH2 or can it be via cat5e structured cabling (there are 2 wall ports)? The run is probably 15-20m max I guess via a patch panel. I could then choose whether to position the HH2 in another location or in the living room.
1 REPLY 1
Message 2 of 2
Re: FTTP Install
If you are prepared to run Ethernet cable you can have the Smarthub sited any where you want.
