Message 1 of 19
FTTP PON light is flashing on my ONT modem, what is wrong?
I have had BT FTTP installed in my flat and have been waiting for it to properly activate for the first time.
The PON light is constantly flashing green on the ONT modem and I am waiting for an Openreach engineer to fix the problem.
I was wondering what exactly the problem could be as I have been waiting since January this year for the new service to be set up.
18 REPLIES 18
Message 2 of 19
Re: FTTP PON light is flashing on my ONT modem, what is wrong?
Your service has not been activated but you have physical connectivity.
Message 3 of 19
Have you phoned the FTTP TEAM 08005874787 and see if the can help you get switched on
Message 4 of 19
Is this flat a new build , you are the first occupant and the ONT was already in place when you moved in ?, if so , the chances are developers fitted the ONT on Openreach’s  behalf ( a job OR pay them to do ) but the developers can’t connect ( splice ) the fibre infrastructure  , when the flat is ‘called off’ as ready for occupation the developer should let their OR contact know, and the OR contact ( FBC /new site rep ) arranges for an OR engineer to splice the connection through and authenticate the ONT with the headend.
If the developer has fitted the kit , and allowed occupation of the flat but either hasn’t advised OR of that fact , or the developer built these properties in a different order to how they advised OR initially the site was to progress ( for example the developer said to OR the first phase was the ‘east’ of the site and would progress ‘west’ , so OR program work to start at the east entrance to the site ,)  the developer then builds something at the ‘west’ side , when the OR network is still being built east to west , then the occupants of that building have to wait for the network to reach them……chances are your developer hasn’t kept OR informed, and unlike water and electricity, developers can ‘sell’ buildings without ‘broadband’ they cannot sell buildings without water or electricity.
Obviously, if none of this applies to you, then it cannot be your issue , but if your address was retro fitted with FTTP on top of the copper pair network, then if the ONT was never authenticated ( the flashing PON signifies it isn’t ) then the OR installer shouldn’t have booked the install off as ‘done’
Message 5 of 19
@iniltous  If the PON light is flashing green, all physical work has been completed. It would be red if it wasn't.
Message 6 of 19
Yes , you are correct, if it were not through to the headend, the LOS light would be lit , the flashing PON does indeed signify the physical connection is made , I should really read the post more carefully 😳
Message 7 of 19
Had an email from BT stating my problem is an 'open exception called FTTP TCP SURVEY RESPONSE FAILURE'. Not sure exactly what that is.
Message 8 of 19
Hi @markt99 and thanks for posting.
Have you had any updaes on this? Has there been any movement?
Cheers
David
Message 9 of 19
BT are going to get back to me on 16/3.
Message 10 of 19
Never got back to me on 16th March, I phoned up BT the next day and they are going to escalate the case with Openreach. Heard nothing else since.
