Message 21 of 27
Re: FTTP is becoming unstable
@Keith_Beddoe That's not the experience I've had, when have you experienced that low?
Message 22 of 27
The stay fast guarantee pn the 500 package is 250, as you are well above that complaining to them about speed will not get you very far
Message 23 of 27
@JonMace Though the stay fast guarantee does not apply to LOS, so therefore a complaint is warranted right?
Message 24 of 27
Definitely, say something about that, but if its working above the guarantee, when they fix the issue its unlikely that the speed will go up with the speed you currently have.
Unles it keeps dropping out I might be inclined to ignore tge light, in trying to fix it it is possible that your speed could be turned down. Bare in mind that the guarantee is 250 and you are getting 440 so they could dial your speed down to see if it's more stable
Message 25 of 27
Also use the speed  test on the BT app as that test the speed to the router as well as to the computer and also checks for errors, and its what the call centre will use
Message 26 of 27
@JonMace
This is FTTP, not FTTC, they don't have DLM for FTTP.
Message 27 of 27
I managed to do a factory reset on the router today and so far my original speeds have returned. 🤞
