Message 1 of 6
Upgraded from FTTP 500 to FTTP 900 and upload speed is capped
Hi,
I upgraded to FTTP 900 (which kicked in on tue morning) and the download speeds look fine (amazing!), however the upload speed appears to be capped at around 60mbps 😞 I've read numerous threads that say it'll sort itself eventually but 3 days in it's still showing this:
As per other posts I've left the Smart Hub 2 connected, though eventually I intend to plug my Ubiquiti USG3 back in that I was using for the FTTP 500 service. I should note too that even using the USG3 the FTTP 900 upload speed is still capped at around 60.
Is there anything else I can do my end or is it something BT have to 'fix'?
cheers,
Laurence
5 REPLIES 5
Message 2 of 6
Re: Upgraded from FTTP 500 to FTTP 900 and upload speed is capped
Hey @laurencemarr,
Thanks for reaching out to us.
I was chatting with Tasha earlier, about this. It's in hand now and as soon as she gets an update, she will get back to you again.
DanielS
Message 3 of 6
thanks very much @DanielS, I was just coming back to this post to say Twitter support were very helpful and have raised a request to get it sorted. I'm assuming that was Tasha 🙂
Message 4 of 6
My internet went down for a few minutes, so I figured the guys were doing something to sort it and low and behold after I ran the built-in speed test and getting the following 👏
I'll try the USG3 shortly here and continue to monitor but it looks like it's been fixed 🙂 i've PMd the Twitter guys as well to let them know
I'd be keen (and probably others too) to understand what was changed, a profile setting on the backend or something on the smart hub 2 itself? If the later, hopefully my 3rd party router will still show similar speeds to that above 🤞
Message 5 of 6
AND the USG3 is working fine now too so must have been a backend thing, so pleased it's all resolved 🙂
Message 6 of 6
Hey @laurencemarr
Many thanks for posting back to let us know your upload speed looks good now.  I am really pleased to see that 😊
I have marked your post as the solution for you too.
Have a nice weekend!
All the best,
Robbie
