Message 1 of 17
Failed to upgrade
Hopefully a moderator can help @JohnC2 @PaddyB @DanielS @NeilO @DavidM
My upgrade From BT Full Fibre 500 to Full Fibre 900 took place today, unfortunately my download & upload speeds have stayed at the Full Fibre 500 speeds and I’ve not seen any increase at all, I’ve rang the full fibre team 08003289393 and found them unhelpful, can a mod help please?
16 REPLIES 16
Message 2 of 17
Re: Failed to upgrade
Call the FTTP team 0800 587 4787
Message 3 of 17
Thanks but goes to the same department. They are saying I have the full 900 to the ONT, unfortunately thou my SH2 is only running at 500 thou.
Message 4 of 17
what package shows on MYBT and can you see upgrade order completed
Message 5 of 17
Full fibre 900 halo 3+ and showing complete.
im doing a fast.com speed test from a iPhone 11 over wifi and it’s coming back at approx 500 download
if I go via the BT app I get the following …
Message 6 of 17
Hi @Bermo,
Welcome to the Community and thank you for posting. I'm sorry if you haven't seen your speeds increase after upgrading to the Fibre 900 package. When did the order complete?
You could try restarting the ONT and then your router to see if that gives the speed a kick to the new profile.
Thanks,
Paddy
Message 7 of 17
@PaddyB - Rebooted both ONT  then router and download speed via fast.com is still 500mbps
order completed today
Message 8 of 17
Hi @Bermo,
Thank you for posting back. I can take up until midnight on the day the order completes for the speeds to increase.
I'd give it until tomorrow and see how the speed are then.
If you don't see an increase then, post back and I'll take a look at this for you.
Thanks,
Paddy
Message 9 of 17
can you try using ethernet connection instead of wireless  https://fast.com/
Message 10 of 17
I think you are just seeing the limitations of wifi.. use an ethernet cable on a pc and you will see full speed
