Message 21 of 22
Re: Fibre Broadband and DV again and acceptance.
If you are indeed being moved to full FTTP, then the 36Mbps that you say BT is guaranteeing you is woefully, even unbelievably, slow.
That's why I suggested that actually you are being moved to FTTC.
All of the FTTC profiles are available on FTTP as well as speeds FTTC can’t deliver , a 36Mb guarantee on a 40Mb Esential service can hardly be described as unbelievably slow, 90% if the headline speed ,
As the OP confirms ( and TBH was pretty clear from the outset )  its  FTTP they are getting , Openreach and by extension, ISP’s  don’t push migration to FTTC from ADSL  , as stated what’s the point swapping one copper based service for another , knowing at some point another migration to FTTP will be necessary
Message 22 of 22
@HHGTTGwrote:
@COMPANY-PENSIONER
What did you get then FTTP or FTTC?
The BT-Order was for a Analogue to Digital DV change-out, over my existing service. The order didn't relate in any way to my situation. When the change-over took place, the bogey order disappeared and my Products & Services pages displayed my correct requirements.
As for FTTP, not readily available.
https://community.bt.com/t5/BT-Fibre-broadband/Non-Existent-Fibre-Broadband/m-p/2436203#M360860
