Message 1 of 4
Fibre cable ducting
Hi, I am currently doing some work at a clients property and he has received a letter to say he will be having fibre installed soon. He has asked for us to put a duct in from the bt cover on the road to his property while we have the garden dug up.
I was just wondering what the spec is for the ducting and if it needs to be a certain size/ colour and depth.
3 REPLIES 3
Message 2 of 4
Re: Fibre cable ducting
You would need to ask Openreach. This is a BT retail forum. If his current service is underground, Openreach will use the existing duct to provide the fibre.
Message 3 of 4
Check this link out for new housing developments,  it should give you sizes
https://www.openreach.com/building-developers-and-projects/fibre-for-developers/guides-and-handbooks
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 4
Hi @jra0401 and welcome to our community.
Further to @Devon_Dave reply you'll get the information at Quick guide duct laying V2 web.pdf.
Cheers
David
