Message 1 of 6
Flashing Orange Light
Wifi has worked fine for months. Today stopped working, orange flashing light. Have turned off/on plugged in and out, even factory reset. Still flashing orange. The open reach wall socket looks like it has a light for the wifi connection? Not sure though but no light showing here either.
5 REPLIES 5
Message 2 of 6
Re: Flashing Orange Light
Provided you don't have digital voice can you check to see if you have a dial tone on your landline phone
Message 3 of 6
Hello, don’t have a landline phone unfortunately. Not sure how to check this without?
Message 4 of 6
The most basic test checking for dial tone. Maybe you can borrow a phone to test
Have you checked to see if there are problems in your area due to recent bad weather?
Message 5 of 6
Hi, yes I had a look and there doesn’t seem to be an unusual amount of reports in the area. Okay I will try and get hold of a landline phone then. Thank you for your help.
Message 6 of 6
Not sure what you mean by that, are you on FTTC or FTTP
