Message 1 of 5
Full Fibre 1
Hi
What type of Hub is required  for the Full Fibre 1 package - broadband only - no phone line
Margaret
4 REPLIES 4
Message 2 of 5
Re: Full Fibre 1
If you mean third party router,  any with a WAN port that supports PPPoE (which will be virtually every router)
If you mean which BT hub, the Smart Hub2 or a Hub4 with a red WAN port.
Message 3 of 5
Re: Full Fibre 1
I have no idea
I have referred a friend and they have picked this package, just something simple
When you select this package on the BT site, you have to select a hub
Some mention modems
They only want broadband, no phone line, no extras
Margaret
Message 4 of 5
Re: Full Fibre 1
@maggsmcgowan wrote:
I have no idea
I don't think you do, you will be supplied a Smart Hub2
Some mention modems
Are you sure its the BT site you are looking at, with full fibre a fibre modem (ONT) will be fitted as part of the installation
Same hub and ONT supplied regardless
Margaret
Are you sure it is full fibre and not just fibre 1? Either way BT will supply the hub, you won't get a choice. No ONT will be fitted for Fibre 1 as it is delivered from the green cabinet via the normal copper phone line.
Message 5 of 5
Re: Full Fibre 1
Thank you for your help, they have managed to place the order
