Message 11 of 28
Re: Full fibre install, PON flashing
This isn’t the OP’s first post on their issue  , I would suggest reading  the previous ones , that will result in more informed responses.
Message 12 of 28
@iniltous  Ah...seems to be quite a history there then.  You would have thought the OP would have mentioned it was a long term issue and would realise it wasn't something trivial by now then.
Message 13 of 28
It’s been going on since last year? 😳
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 14 of 28
Phoned BT and they said a chief engineer has been allocated to fix the problem at the exchange.
Message 15 of 28
Getting compensation from BT  again for failing to deliver working full fibre to my property.
Message 16 of 28
Chief Engineers. 😆
If it’s same so called Chief Engineers that were there when I was then they’d be better off sending out a Kelly’s Contractor who just finished his Training this afternoon.
Message 17 of 28
That's what I've been repeatedly told, they are trying to allocate 'chief engineers' to fix the issue whatever chief engineer means at Openreach.
Message 18 of 28
To be honest it doesn’t actually mean anything.
It’ll just be an Openreach Engineer, Technician or whatever you want to call them.
When I was there people who worked for the so called Chief Engineers were the Golden Boy’s who probably Brown Nosed their way into it.
Anyway, doesn’t matter as I was told by a mate whose still at Openreach that the Chief Engineers has been merged with the even more useless Fibre Network Delivery to form a new Group called Complex Engineering.
I can only imagine what a useless shower of chit most of them are.
Message 19 of 28
Message 20 of 28
I phoned BT and have been told my order is cancelled as Openreach  could not fix the issue. I live in a block of flats and they labelled  problems with the full fibre install in a multi dwelling unit to blame.
To get full fibre enough people in the block now have to sign a notification of interest to Openreach, then something along the lines of a Openreach multi dwelling install unit will sort out the issue, but until then no full fibre at my address. 😬😵💫🤮
