Message 1 of 2
Full fibre
Just been connected to full fibre. BT App shows 950Mbps in router room, room next door and upstairs. AVG speed test on my phone 169, 33 and 43, and the Which? speed test site shows 65,46 and 46 respectively. Are there different methods for measuring speed to give these wildly diverging results ?
1 REPLY 1
Message 2 of 2
Re: Full fibre
using wifi to check speed will always vary and unlikely to get same speed twice in a row.  also depends on connecting to 2.4 or 5ghz network  only correct way is using ethernet connection
