Message 11 of 15
Re: Gaming Broadband
his and mine pc,s.
Message 12 of 15
Have you tried his pc on your connection?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 13 of 15
Yes it’s the same all the bs you get on warzone and multiplayer if the connection isn’t godly.
Its the same on the ps4 aswell.
Going to try the proxy from previous post later on.
Message 14 of 15
Re: Gaming FTTP Broadband
Hello Ted I turned the proxy off on the pc was a major hit in terms of latency/gameplay I would say it is slightly off now put improved in terms off gameplay. Any other tips I think I’ve tried everything else though !.
Message 15 of 15
I had BT uninstalled for zen 😄
