Message 21 of 22
Re: Half speed uploads
Hi @Stoneblade, thanks for your PM over the weekend and good to know you're now seeing the correct speeds. I've arranged for a replacement Smart Hub also for you.
Cheers
John
Message 22 of 22
Thanks @JohnC2 and the other helpful people who responded.  Line has steadied and seems to be back where it was meant to be.
