Message 1 of 24
How do I contact BT with fault?
I have fibre 900/110 but my upload is coming out at 20Mbps.
I cant seem to find anywhere to register a fault, the website just goes around in circles...
I have a Smarthub 2
thanks
23 REPLIES 23
Message 2 of 24
Re: How do I contact BT with fault?
0800 800 150
Is that using Wifi or an Ethernet connection? If Wifi you need to test using an Ethernet connection.
Message 3 of 24
Ethernet (wired)  - I don't use wifi at all.
Message 4 of 24
What speed do you get if you try fast.com
Message 5 of 24
SpeedSpeed
Message 6 of 24
Try a factory reset of the hub.
Message 7 of 24
It says I am connected 1000Mbps up and down, but not getting the upload speed.
Message 8 of 24
Also... I was checking to see what firmware the smarthub is on. It seems the lastest is
Firmware v0.33.00.12274-BT
But mine is a 0.15.00.06145
Message 9 of 24
The hub will always report 1000Mbps, that is the speed of the link between the ONT and the hub.
That is very old firmware, your hub should have updated to the latest version.
Are you leaving the hub switched on 24/7, it is unlikely to update unless you do.
Message 10 of 24
I havent used the hub in a year or so.
Is there a way of forcing it to update?
thanks
PS what is ONT?
