Message 11 of 24
Re: How do I contact BT with fault?
according to your stats you are connected to a BT smart hub which is connected to an ONT - small white box
you cannot update hub firmware manually as does it automatically
Message 12 of 24
That's why it hasn't updated, you need to leave it connected, you can't force an update.
ONT is the optical modem that your hub connects to.
PS any chance of changing your avatar, it's totally distracting
Message 13 of 24
Is that better? 🤣
Message 14 of 24
No, it's worse 😱
Message 15 of 24
How about now?
Message 16 of 24
It's not updating - still on old firmware ☹️
Message 17 of 24
there is no set timescale for your hub firmware to update. you just need to leave hub powered up connected to the internet.  normally happens overnight but could be tonight, next week or next month
Message 18 of 24
Well I need to contact BT anyway then... I think they guarentee speeds and i get money back if they aren't the minmum of quoted.
https://www.bt.com/help/broadband/what-is-bt-s-stay-fast-guarantee-
Message 19 of 24
Bear in mind the guaranteed speeds are connection speeds to the hub not connection or download speeds at any device
Message 20 of 24
Definitely something wrong - BT couldn't even query the router properly, with error message "unrecognised equipment" or words to that effect. He said thats why it's not updating.
BT engineer coming out next week.
thanks for all the replies
