Message 21 of 24
Re: How do I contact BT with fault?
have you tried a factory reset of the hub as suggested by @licquorice
if not then try that by pressing the recessed but on back with say paperclip and holding until the hub lights flash and then let hub reboot and go blue colour.  as you use ethernet connection no problems with wifi devices  and now see if that has helped your connection improve
Message 22 of 24
Yes, I reset when first advised to.
thanks
Message 23 of 24
sorry but did you hold recess button 20/30 secs until lights flash otherwise just resets not factory resets
Message 24 of 24
Yes 👍
