Message 11 of 17
Re: Hub light orange
It's OK I'm not looking for assistance here, apparently it's an external fault. But to answer your Q, the power light is green, LOS is red, PON doesn't appear to be illuminated at all, LAN is green. What's ONT?
Message 12 of 17
Optical Network Terminal
Message 13 of 17
...and the red loss light means a physical fault with the connection, such as a break in the fibre optic cable etc.
Message 14 of 17
As far as why there is now a problem, it’s impossible to know , there may be a complete break in the fibre , there may be a high loss , or your ONT may have developed a fault , it’s likely that the problem is the splitter forward towards your ONT , so only you affected , but it’s possible the problem is splitter back towards the headend and affecting all the members of the PON , so unto 30 customers , but it’s not likely that OR have 100% take up , so many fewer if the PON is out of order .
With lots of companies allowed access to Openreach physical infrastructure, like ducts , joint boxes and poles , it’s possible someone has damaged OR cables while working on  /installing a competitor company cables or equipment , there are quite a number of possibilities, but it’s nothing more than speculation until OR visit and locate the issue , even when fixed , although the defect can be identified the reason for it may never be known
Message 15 of 17
Thank you, very interesting.
Message 16 of 17
Quick update. Openreach fixed the problem. The fibre where it entered the box on the wall of the house had been put in with too tight a radius and had split. The OR person that fixed the problem was diplomatic but it was installed by a contractor who was probably paid by the job!
Message 17 of 17
Thanks for coming back and letting us know, the problem has now been fixed @Thompson218
Leanne 🙂
