Message 1 of 5
Install Tomorrow - Master Socket Question
Have my fibre 250 install tomorrow AM between 7 and 9, had the reminder email, and it suggested the engineer would upgrade the master socket and put it in the best place for me.
Is that right?  I want the socket moved anyway, as it’s coming in on a bedroom on the 1st floor, and my preference would be for it to come in on the ground floor, same wall/side of the house. (House used to have two lines, now it’s just one)
Would that be covered, or do I still need to progress with a master socket move after the install of my fibre 250
I have the latest master socket, so guessing it’s going to be the latter?
Ta!
4 REPLIES 4
Message 2 of 5
Re: Install Tomorrow - Master Socket Question
With FTTP the existing socket is not involved. The engineer will site the ONT (the Optical Network Termination) where you wish, within reason.
You will need a mains power supply to power the ONT and the Smart Hub ie two sockets.
The engineer may need to route cable down the outside of the property
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 3 of 5
Ta! Sorry, forgot to say that it’s FTTC, (g fast) moving from sky 😉
Message 4 of 5
Then you can ask the engineer if he will move it, most are pretty amenable. Have tea/coffee and biscuits on hand.
Message 5 of 5
🙂 I’ll make sure the kettles on!
looking forward to some more speed 🙂
