Message 1 of 17
Joke of a company slow upload speed fttp
Joke of a company , led to believe I would receive 110 upload speed to then only receive 50 then all there answer is it states in your contract min guarantee 10mb upload , stay clear over priced to other competitors shame I’m still within contract,,,!
16 REPLIES 16
Message 2 of 17
Re: Joke of a company slow upload speed fttp
Is this a new fibre 900 connection?  If so there are numerous posts like yours and your upload speed  takes a couple of days to get to correct speed.  If connection more than 3/4 then post back and we can see if mods can help you get correct speed
Message 3 of 17
Had fttp 900 halo 3 since April just noticed lower upload speed, can’t trust any companies now all the same
Message 4 of 17
If been like that since April then you need help so have asked mods for assistance  they will post here
Message 5 of 17
Spoke to fttp tech team well within your agreed speeds Which upload min is 50mb upload, which is understandable but I know those speeds can be achieved there just throttling it
Message 6 of 17
@Witton90wrote:
 just throttling it
There it is, BT don't throttle anything
Hopefully the mods will be able to resolve this for you
Message 7 of 17
Sigh, nobody is throttling anything. The hub needs a remote config change which enables the increased speed. This normally happens after a couple of days but sometimes gets stuck and requires manual intervention. The mods will sort it.
Had you taken a few moments to look through the countless other posts on the forum with the same issue, you would have realised this.
Message 8 of 17
Hi @Witton90,
Welcome to our Community.
I am sorry that you haven't been able to get the help that you need after trying. I've sent you a private message so my team can pick this up and find out what we can do to help you.
DanielS
Message 9 of 17
Sorry don’t know how it works throttling or stuck at speeds as lower package same thing
Message 10 of 17
Although the result is the same - lower speed - throttling Is intentional whereas a config problem is not intentional and only happens to some hubs.  Surprised it has taken you so long to notice the config problem.  Have you replied to the mod private message so you can get config file updated?
