Message 1 of 7
ONT location
Oh what a dilemma it is moving provider.  Open reach coming 16th Aug.  My TV,  and hopefully my router will be in the rear room at the back of the house, I have space on the wall behind the TV  for the ONT bix and it is the only place I have double sockets currently free.  I would like the cable to come in via the back wall as then only 1 hole to drill near the sockets.  Does anybody know if they can do that, possibly running cable around outside wall to entry point.  If not this could be a deal settler.
6 REPLIES 6
Message 2 of 7
Re: ONT location
Hopefully sorted as new location selected same room but where it should be easy to run cable inside the house. Fingers crossed
Message 3 of 7
Re: ONT location
Within reason cable can be routed on an outside wall and enter the house at a convenient point.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 4 of 7
Re: ONT location
Thanks, thought it would be but think I've now figured a way inside that will work.
Message 5 of 7
Re: ONT location
They’ll need to drill 3 holes inside.
2 for the screws to hold the ONT in place and one to the outside for the cable.
Message 6 of 7
Re: ONT location
Maybe 4 inmy case as may have to go through an internal wall
Message 7 of 7
Re: ONT location
@spd1954  Then your solution complictes the issue as the external sheath needs stripping from point of entry = more work for engineer which he/she may not consider necessary.
Bottom line, keep it simple.
