Message 1 of 6
Keeps disconnecting
Hi, can anybody help solve a problem, my broadband keeps disconnecting, it had disconnected six times so far today,  I've had two engineers out in the past couple of months and they couldn't find a fault.
I had no problems with my previous provider
13:11:45 15 Oct. ARP [add] br0(wl1) 192.168.1.170 0e:a2:f4:46:69:c9
13:11:45 15 Oct. ARP [del] br0 192.168.1.170 0e:a2:f4:46:69:c9
13:10:54 15 Oct. ARP [add] br0(wl1) 192.168.1.170 0e:a2:f4:46:69:c9
13:10:53 15 Oct. ARP [del] br0 192.168.1.170 0e:a2:f4:46:69:c9
13:05:47 15 Oct. ARP [add] br0(wl1) 192.168.1.170 0e:a2:f4:46:69:c9
13:05:47 15 Oct. ARP [del] br0 192.168.1.170 0e:a2:f4:46:69:c9
13:04:51 15 Oct. ARP [add] br0(wl1) 192.168.1.170 0e:a2:f4:46:69:c9
13:04:51 15 Oct. ARP [del] br0 192.168.1.170 0e:a2:f4:46:69:c9
13:04:49 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:04:48 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:04:48 15 Oct. ARP [add] br0(wl0) 192.168.1.117 54:e0:19:15:a6:73
13:04:44 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:04:43 15 Oct. DHCP device Connected: 192.168.1.117 54:e0:19:15:a6:73 Ring-15a673
13:04:43 15 Oct. DHCP lease issued 192.168.1.117 to 54:e0:19:15:a6:73 Ring-15a673 lease duration is 86400 seconds
13:04:43 15 Oct. 5G Client associate from 54:e0:19:15:a6:73 (IP=192.168.1.117) RSSI=-60 Rate=65Mbps host Ring-15a673
13:04:43 15 Oct. LAN [ADD] ARP 192.168.1.117 with 54:e0:19:15:a6:73 from br0(wl0)
13:04:43 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:04:42 15 Oct. Receive a DHCP request
13:04:42 15 Oct. WHW INFO A station (SmartHub2)IF[5G](8C:19:B5:47:84:ED):STA(54:E0:19:15:A6:73)(Legacy Device) join WHW infrastructure
13:04:31 15 Oct. CWMP: HDM socket closed successfully.
13:04:31 15 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
13:04:31 15 Oct. CWMP: HDM socket opened successfully.
13:04:31 15 Oct. CWMP: session completed successfully
13:04:30 15 Oct. CWMP: HDM socket opened successfully.
13:04:30 15 Oct. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
13:04:30 15 Oct. CWMP: Session start now server: https://pbthdm.x.x.x Event code: 4 VALUE CHANGE
13:04:30 15 Oct. CWMP: Initializing transaction for event code 4 VALUE CHANGE
13:04:25 15 Oct. LAN [DEL] ARP 192.168.1.117 with 54:e0:19:15:a6:73 from br0
13:04:23 15 Oct. WHW INFO A station STA(54:E0:19:15:A6:73) leave WHW infrastructure
13:04:23 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:04:22 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:04:22 15 Oct. 5G Client associate from 54:e0:19:15:a6:73 (IP=192.168.1.117) RSSI=-61 Rate=65Mbps host Ring-15a673
13:04:22 15 Oct. Receive a DHCP request
13:04:21 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:04:20 15 Oct. DHCP device Connected: 192.168.1.117 54:e0:19:15:a6:73 Ring-15a673
13:04:20 15 Oct. DHCP lease issued 192.168.1.117 to 54:e0:19:15:a6:73 Ring-15a673 lease duration is 86400 seconds
13:04:20 15 Oct. 5G Client associate from 54:e0:19:15:a6:73 (IP=192.168.1.117) RSSI=-57 Rate=6Mbps host Ring-15a673
13:04:20 15 Oct. LAN [ADD] ARP 192.168.1.117 with 54:e0:19:15:a6:73 from br0(wl0)
13:04:20 15 Oct. Receive a DHCP request
13:04:20 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:04:19 15 Oct. WHW INFO A station (SmartHub2)IF[5G](8C:19:B5:47:84:ED):STA(54:E0:19:15:A6:73)(Legacy Device) join WHW infrastructure
13:04:17 15 Oct. admin login success from 192.168.1.214
13:04:09 15 Oct. admin login error from 192.168.1.214
13:04:01 15 Oct. WHW INFO A station STA(54:E0:19:15:A6:73) leave WHW infrastructure
13:03:46 15 Oct. admin timeout from 192.168.1.214
13:03:46 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:03:45 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:03:38 15 Oct. NTP synchronization success
13:03:37 15 Oct. NTP Server: ntp.homehub.btopenworld.com
13:03:37 15 Oct. ARP [add] br0(wds0.4.1) 192.168.1.144 30:ae:a4:0c:74:9c
13:03:37 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:03:34 15 Oct. WHW INFO A station (SmartHub2)IF[5G](8C:19:B5:47:84:ED):STA(54:E0:19:15:A6:73)(Legacy Device) join WHW infrastructure
13:03:30 15 Oct. LTE Modem owl_tx_lte_set_rate_shaper_script command sent
13:03:29 15 Oct. DHCP device Connected: 192.168.1.144 30:ae:a4:0c:74:9c espressif
13:03:28 15 Oct. DHCP device Disconnected: 192.168.1.144 30:ae:a4:0c:74:9c espressif
13:03:28 15 Oct. LTE Modem owl_tx_lte_set_rate_shaper_script command sent
13:03:28 15 Oct. LAN [ADD] ARP 192.168.1.144 with 30:ae:a4:0c:74:9c from br0(wds0.4.1)
13:03:28 15 Oct. WHW INFO A station (Bedroom)IF[2.4G](44:FE:3B:89:2E:37):STA(30:AE:A4:0C:74:9C) join WHW infrastructure
13:03:28 15 Oct. LAN [DEL] ARP 192.168.1.144 with 30:ae:a4:0c:74:9c from br0
13:03:27 15 Oct. Receive a DHCP request
13:03:26 15 Oct. WAN Sensing Auto sensing Complete interface selected
13:03:26 15 Oct. Port forwarding rule added via UPnP/TR064. Protocol: UDP external ports: any->3074 internal ports: 3074 internal client: 192.168.1.206
13:03:26 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:03:23 15 Oct. ARP [del] br0 192.168.1.144 30:ae:a4:0c:74:9c
13:03:23 15 Oct. WAN Sensing Auto sensing Running
13:03:22 15 Oct. WAN IPv6 Global unicast prefix / length: 2a00:23c5:fc86:a400::/56
13:03:22 15 Oct. WAN IPv6 Global unicast address allocated: 2a00:23c5:fc86:a400::1/64
13:03:22 15 Oct. WAN DHCPv6 events: BOUND
13:03:21 15 Oct. NTP synchronization start
13:03:21 15 Oct. WAN DHCPv6 events: INIT
13:03:21 15 Oct. WAN Sensing Auto sensing Complete interface selected
13:03:20 15 Oct. WAN Sensing Auto sensing Running
13:03:20 15 Oct. Success - secondary DNS servers
13:03:20 15 Oct. Success - primary DNS servers
13:03:20 15 Oct. WAN connection WAN2_INTERNET_PTM connected
13:03:20 15 Oct. PPP: IPCP up
13:03:20 15 Oct. PPP IPCP Receive Configuration ACK
13:03:20 15 Oct. PPP IPV6CP Receive Configuration ACK
13:03:20 15 Oct. PPP IPCP Send Configuration Request
13:03:19 15 Oct. PPP IPCP Receive Configuration NAK
13:03:19 15 Oct. PPP IPCP Send Configuration ACK
13:03:19 15 Oct. PPP IPCP Receive Configuration Request
13:03:19 15 Oct. PPP IPV6CP Send Configuration ACK
13:03:19 15 Oct. PPP IPV6CP Receive Configuration Request
13:03:19 15 Oct. PPP IPV6CP Send Configuration Request
13:03:19 15 Oct. PPP IPCP Send Configuration Request
13:03:19 15 Oct. PPP: CHAP authentication succeeded
13:03:19 15 Oct. PPP CHAP Receive success : authentication successful
13:03:19 15 Oct. PPP CHAP Receive Challenge
13:03:19 15 Oct. PPP: LCP up
13:03:19 15 Oct. PPP LCP Receive Configuration ACK
13:03:18 15 Oct. PPP LCP Send Configuration ACK
13:03:18 15 Oct. PPP LCP Receive Configuration Request
13:03:18 15 Oct. PPP LCP Send Configuration Request
13:03:18 15 Oct. PPP: Received PADS
13:03:18 15 Oct. PPP: Sending PADR
13:03:18 15 Oct. PPP: Received PADO
13:03:18 15 Oct. PPP: Sending PADI
13:03:18 15 Oct. ARP [del] br0 192.168.1.117 54:e0:19:15:a6:73
13:03:14 15 Oct. LAN [DEL] ARP 192.168.1.117 with 54:e0:19:15:a6:73 from br0
13:03:13 15 Oct. PPP: Sending PADI
13:03:12 15 Oct. WHW INFO A station STA(54:E0:19:15:A6:73) leave WHW infrastructure
13:03:08 15 Oct. PPP: Sending PADI
13:03:03 15 Oct. DHCP device Connected: 192.168.1.206 1c:1a:df:85:28:58 XBOX
13:03:03 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:03:03 15 Oct. PPP: Sending PADI
13:03:03 15 Oct. 5G Client associate from 1c:1a:df:85:28:58 (IP=192.168.1.206) RSSI=-55 Rate=780Mbps host XBOX
13:03:03 15 Oct. LAN [ADD] ARP 192.168.1.206 with 1c:1a:df:85:28:58 from br0(wl0)
13:03:02 15 Oct. Receive a DHCP request
13:03:02 15 Oct. WHW INFO A station (SmartHub2)IF[5G](8C:19:B5:47:84:ED):STA(1C:1A:DF:85:28:58)(Legacy Device) join WHW infrastructure
13:03:00 15 Oct. DSL Link Up: Down Rate=54999kbps Up Rate=9480kbps; SNR Margin Down=3.6dB Up=6.2dB
13:02:59 15 Oct. DHCP device Disconnected: 192.168.1.206 1c:1a:df:85:28:58 XBOX
13:02:59 15 Oct. LAN [DEL] ARP 192.168.1.206 with 1c:1a:df:85:28:58 from br0
13:02:58 15 Oct. 5G Client disassociate from 1c:1a:df:85:28:58 (IP=192.168.1.206) RSSI=0 Rate=0Mbps
13:02:58 15 Oct. PPP: Sending PADI
13:02:57 15 Oct. WHW INFO A station STA(1C:1A:DF:85:28:58) leave WHW infrastructure
13:02:53 15 Oct. PPP: Starting PPP daemon
13:02:52 15 Oct. WAN Auto-sensing detected port DSL WAN
13:02:40 15 Oct. SIP WAN DOWN
13:02:31 15 Oct. SIP WAN DOWN
13:02:31 15 Oct. WAN Sensing Auto sensing Complete interface selected
13:02:31 15 Oct. WAN Sensing Auto sensing Running
13:02:29 15 Oct. WAN Sensing Auto sensing Complete interface selected
13:02:29 15 Oct. WAN Sensing Auto sensing Running
13:02:28 15 Oct. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
13:02:28 15 Oct. ARP [add] br0(wl1) 192.168.1.144 30:ae:a4:0c:74:9c
13:02:28 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
13:02:27 15 Oct. PPP: Stopped PPP daemon(0 1 5)
13:02:27 15 Oct. PPP LCP Send Termination Request (User request)
13:02:27 15 Oct. PPP: IPCP down
13:02:27 15 Oct. PPP: LCP down
13:02:27 15 Oct. DSL Link Down: duration was 3843 seconds
13:02:19 15 Oct. 2.4G Client associate from 30:ae:a4:0c:74:9c (IP=192.168.1.144) RSSI=-62 Rate=58Mbps host espressif
13:02:19 15 Oct. WHW INFO A station (SmartHub2)IF[2.4G](8C:19:B5:47:84:EE):STA(30:AE:A4:0C:74:9C)(Legacy Device) join WHW infrastructure
13:02:19 15 Oct. Receive a DHCP request
13:02:19 15 Oct. WHW INFO A station STA(30:AE:A4:0C:74:9C) leave WHW infrastructure
12:58:41 15 Oct. WHW INFO A station STA(D2:5A:8A:9E:A1:6F) leave WHW infrastructure
12:55:57 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
12:55:56 15 Oct. ARP [add] br0(wds0.4.1) 192.168.1.144 30:ae:a4:0c:74:9c
12:55:24 15 Oct. WHW INFO A station (Bedroom)IF[2.4G](44:FE:3B:89:2E:37):STA(30:AE:A4:0C:74:9C) join WHW infrastructure
12:55:24 15 Oct. Receive a DHCP request
12:54:26 15 Oct. Receive a DHCP request
12:54:18 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
12:54:16 15 Oct. 2.4G Client associate from 30:ae:a4:0c:74:9c (IP=192.168.1.144) RSSI=-63 Rate=58Mbps host espressif
12:54:16 15 Oct. WHW INFO A station (SmartHub2)IF[2.4G](8C:19:B5:47:84:EE):STA(30:AE:A4:0C:74:9C)(Legacy Device) join WHW infrastructure
12:54:16 15 Oct. Receive a DHCP request
12:54:16 15 Oct. WHW INFO A station STA(30:AE:A4:0C:74:9C) leave WHW infrastructure
12:52:25 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
12:52:13 15 Oct. ARP [add] br0(wl1) 192.168.1.144 30:ae:a4:0c:74:9c
12:52:06 15 Oct. DHCP device Connected: 192.168.1.144 30:ae:a4:0c:74:9c espressif
12:52:05 15 Oct. DHCP lease issued 192.168.1.144 to 30:ae:a4:0c:74:9c espressif lease duration is 86400 seconds
12:52:05 15 Oct. 2.4G Client associate from 30:ae:a4:0c:74:9c (IP=192.168.1.144) RSSI=-64 Rate=58Mbps host espressif
12:52:05 15 Oct. LAN [ADD] ARP 192.168.1.144 with 30:ae:a4:0c:74:9c from br0(wl1)
12:52:05 15 Oct. Receive a DHCP request
12:52:05 15 Oct. WHW INFO A station (SmartHub2)IF[2.4G](8C:19:B5:47:84:EE):STA(30:AE:A4:0C:74:9C)(Legacy Device) join WHW infrastructure
12:50:47 15 Oct. DHCP device Connected: 192.168.1.214 d2:5a:8a:9e:a1:6f Paul-s-S22-Ultra
12:50:47 15 Oct. LAN [ADD] ARP 192.168.1.214 with d2:5a:8a:9e:a1:6f from br0(wl0)
12:50:47 15 Oct. ARP [add] br0(wl0) 192.168.1.214 d2:5a:8a:9e:a1:6f
12:50:41 15 Oct. WHW INFO A station (SmartHub2)IF[5G](8C:19:B5:47:84:ED):STA(D2:5A:8A:9E:A1:6F)(Legacy Device) join WHW infrastructure
12:50:39 15 Oct. DHCP device Disconnected: 192.168.1.214 d2:5a:8a:9e:a1:6f Paul-s-S22-Ultra
12:50:38 15 Oct. LAN [DEL] ARP 192.168.1.214 with d2:5a:8a:9e:a1:6f from br0
12:50:38 15 Oct. 5G Client disassociate from d2:5a:8a:9e:a1:6f (IP=192.168.1.214) RSSI=0 Rate=0Mbps
12:50:38 15 Oct. WHW INFO A station STA(D2:5A:8A:9E:A1:6F) leave WHW infrastructure
12:50:38 15 Oct. 5G client Mac: D2:5A:8A:9E:A1:6F Deauthentications (Reason:Class 3 frame received from nonassociated station)
12:50:28 15 Oct. WHW INFO A station (Bedroom)IF[5G](44:FE:3B:89:2E:38):STA(D2:5A:8A:9E:A1:6F) join WHW infrastructure
12:50:18 15 Oct. ARP [add] br0(wds0.4.1) 192.168.1.123 54:e0:19:56:91:87
12:50:18 15 Oct. ARP [del] br0 192.168.1.123 54:e0:19:56:91:87
12:43:51 15 Oct. WHW INFO A station STA(D2:5A:8A:9E:A1:6F) leave WHW infrastructure
12:36:07 15 Oct. ARP [add] br0(wl0) 192.168.1.214 d2:5a:8a:9e:a1:6f
12:35:51 15 Oct. WHW INFO A station (SmartHub2)IF[5G](8C:19:B5:47:84:ED):STA(D2:5A:8A:9E:A1:6F)(Legacy Device) join WHW infrastructure
12:35:51 15 Oct. WHW INFO A station STA(D2:5A:8A:9E:A1:6F) leave WHW infrastructure
12:35:41 15 Oct. WHW INFO A station (Bedroom)IF[5G](44:FE:3B:89:2E:38):STA(D2:5A:8A:9E:A1:6F) join WHW infrastructure
12:30:41 15 Oct. ARP [add] br0(wl1) 192.168.1.170 0e:a2:f4:46:69:c9
12:30:41 15 Oct. ARP [del] br0 192.168.1.170 0e:a2:f4:46:69:c9
12:21:13 15 Oct. ARP [add] br0(wl1) 192.168.1.170 0e:a2:f4:46:69:c9
12:21:13 15 Oct. ARP [del] br0 192.168.1.170 0e:a2:f4:46:69:c9
12:20:20 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
12:20:19 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
12:20:16 15 Oct. 2.4G Client associate from 0e:a2:f4:46:69:c9 (IP=192.168.1.170) RSSI=-58 Rate=52Mbps host chameleon-cad-0ea2f44669c9
12:20:16 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
12:20:16 15 Oct. Receive a DHCP request
12:20:15 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
12:20:14 15 Oct. WHW INFO A station (SmartHub2)IF[2.4G](8C:19:B5:47:84:EE):STA(0E:A2:F4:46:69:C9)(Legacy Device) join WHW infrastructure
12:20:14 15 Oct. WHW INFO A station STA(0E:A2:F4:46:69:C9) leave WHW infrastructure
12:19:49 15 Oct. ARP [add] br0(wds0.4.1) 192.168.1.123 54:e0:19:56:91:87
12:19:49 15 Oct. ARP [del] br0 192.168.1.123 54:e0:19:56:91:87
12:06:52 15 Oct. Port forwarding rule added via UPnP/TR064. Protocol: UDP external ports: any->3074 internal ports: 3074 internal client: 192.168.1.206
12:06:25 15 Oct. DHCP device Connected: 192.168.1.206 1c:1a:df:85:28:58 XBOX
12:06:24 15 Oct. 5G Client associate from 1c:1a:df:85:28:58 (IP=192.168.1.206) RSSI=-55 Rate=780Mbps host XBOX
12:06:24 15 Oct. LAN [ADD] ARP 192.168.1.206 with 1c:1a:df:85:28:58 from br0(wl0)
12:06:24 15 Oct. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
12:06:24 15 Oct. Receive a DHCP request
12:06:23 15 Oct. WHW INFO A station (SmartHub2)IF[5G](8C:19:B5:47:84:ED):STA(1C:1A:DF:85:28:58)(Legacy Device) join WHW infrastructure
12:06:21 15 Oct. DHCP device Disconnected: 192.168.1.206 1c:1a:df:85:28:58 XBOX
12:06:21 15 Oct. LAN [DEL] ARP 192.168.1.206 with 1c:1a:df:85:28:58 from br0
12:06:20 15 Oct. 5G Client disassociate from 1c:1a:df:85:28:58 (IP=192.168.1.206) RSSI=0 Rate=0Mbps
12:06:18 15 Oct. WHW INFO A station STA(1C:1A:DF:85:28:58) leave WHW infrastructure
11:59:30 15 Oct. CWMP: HDM socket closed successfully.
11:59:30 15 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
11:59:30 15 Oct. CWMP: HDM socket opened successfully.
11:59:30 15 Oct. CWMP: session completed successfully
11:59:29 15 Oct. CWMP: HDM socket closed successfully.
11:59:29 15 Oct. CWMP: HTTP authentication success from pbthdm.x.x.x
11:59:29 15 Oct. CWMP: HDM socket opened successfully.
11:59:29 15 Oct. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
11:59:28 15 Oct. CWMP: Session start now server: https://pbthdm.x.x.x Event code: 4 VALUE CHANGE
11:59:28 15 Oct. CWMP: Initializing transaction for event code 4 VALUE CHANGE
11:59:05 15 Oct. NTP synchronization success
11:59:05 15 Oct. NTP Server: ntp.homehub.btopenworld.com
11:58:59 15 Oct. LTE Modem owl_tx_lte_set_rate_shaper_script command sent
5 REPLIES 5
Message 2 of 6
Re: Keeps disconnecting
From the log I can see your a VDSL connection so a copper pair line.
Have you tried a "Quiet Line Test" in the past?
Ideally plug in a wired phone dial 17070 and select option 2. Do you hear any line noise e.g. crackling, buzzing, popping? You might hear a 50hz hum which can be normal but it should be slient. If performing over a cordless phone try using the mute function but it won't be totally slient but listen for popping/cracking/scraching.
Message 3 of 6
Thank you for the reply Starman, yes the engineers that came out performed the test and they said it was perfectly fine, the problem started off  intermittently but now it's become a daily occurrence, just very confusing, BT said there are no faults showing up on the line on their end, thr only thing i can think of that is causing the issue is if my smart hub 2 is faulty.
Message 4 of 6
Looking at the logs you posted I can see one drop in internet connection so is the problem more the drops in your wireless connection to devices rather than drops in internet.  does hub light stay blue
With the number of drops in connection you experience if it is hub then I am surprised that your down noise margin is 3.6db whereas I would expect the DLM to have taken action by now and noise margin to be 6db+
Message 5 of 6
No, the hub goes to purple then flashes orange  until goes back to blue when connection starts again.
Message 6 of 6
A >3db SNR on the downstream would likely indicate that G.INT was enabled by DLM on the line in the past.
What kind of line stats are available on the SH2? Any ES SES values available to endusers?
@imjollywrote:
...I am surprised that your down noise margin is 3.6db whereas I would expect the DLM to have taken action by now and noise margin to be 6db+
