Message 1 of 6
Length of ONT full cable in house
Morning all
I would like to know how long the power cable from the new ONT  full fibre internal box   is so I can measure to our nearest electrical socket please.
I would appreciate it f someone could send  me photo of their set up  for eg behind TV to see connections etc.
Jean
5 REPLIES 5
Message 2 of 6
Re: Length of ONT full cable in house
Power cable on some of the Nokia ONTs have been around 1.5 meters in length.
The ONTs look something like:
Here's some information on how Openreach install FTTP
https://www.openreach.com/help-and-support/full-fibre-broadband-installation-checklist
Message 3 of 6
It’s the length of cable you get with a normal ‘wall wart’ plug in PSU. Probably 2m. You can get extensions for these low power DC cables if it is not long enough.
Message 4 of 6
Thankyou for the info.
Question:
Just wondering is the full fibre coming through the wall connected directly into the back of your ONT box?
Message 5 of 6
It plugs into the bottom.  (The green connector in the picture above).
Message 6 of 6
Been a while since I did FTTP Installs but I’m pretty sure the power lead for the ONT is only about 1/2m long.
