Message 1 of 2
Line 'stuck' at 55 down 9 up.
Hello everyone,
I moved to a new property and the only connection I can get is a VDSL2, coming from a previous FTTH connection I'm a bit disappointed but it is what it is, and since my exchange is not an FTTH priority exchange its safe to assume its going to take a couple of years. I've been using VDSL2 before so its okay as long as its stable.
I'm using a Netgear DM200 acting purely as a modem only, and for the main router I'm using an ASUS RT-AC86U.
The Netgear line stats tell me that I can get at least 70 down and 19 up. I'm currently synced at 55 down and 9 up. I know it can take 10 days for the DSLAM to find a stable rate.
I don't mind the download speed since its good enough for my needs, but the upload makes a bit of difference since I work from home and I tend to upload large files to the cloud.
I called BT and they said that the best my line can do is down 40 (I'm synced at 55 so good), but they cannot assume me a solid upload speed. Can anyone shine a light on this or what I can do?
Here are my line stats:
BusyBox v1.28.4 () built-in shell (ash)
BusyBox v1.28.4 (2018-05-22 15:53:59 EDT) built-in shell (ash)
Enter 'help' for a list of built-in commands.
| Lantiq UGW Software UGW-6.1.1 on XRX200 CPE |
root@DM200:~# ./line_stats.sh
local dsl={}
dsl.atuc_vendor_id="Infineon 178.6"
dsl.atuc_system_vendor_id="45,43,49,20,74,65,6C,65"
dsl.chipset="Lantiq-VRX200"
dsl.firmware_version="5.7.11.5.0.7"
dsl.api_version="4.17.18.6"
dsl.xtse1=0x0
dsl.xtse2=0x0
dsl.xtse3=0x0
dsl.xtse4=0x0
dsl.xtse5=0x0
dsl.xtse6=0x0
dsl.xtse7=0x0
dsl.xtse8=0x2
dsl.xtse_s="0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x2"
dsl.annex_s="B"
dsl.line_mode_s="G.993.2 (VDSL2)"
dsl.profile=6
dsl.profile_s="17a"
dsl.line_state_num=0x801
dsl.line_state_detail="showtime_tc_sync"
dsl.line_state="UP"
dsl.errors_fec_near=2817
dsl.errors_fec_far=672451769
dsl.errors_es_near=0
dsl.errors_es_far=92665
dsl.errors_ses_near=0
dsl.errors_ses_far=1456
dsl.errors_loss_near=0
dsl.errors_loss_far=452
dsl.errors_uas_near=35
dsl.errors_uas_far=35
dsl.errors_hec_near=0
dsl.errors_hec_far=0
dsl.errors_crc_p_near=0
dsl.errors_crc_p_far=0
dsl.errors_crcp_p_near=0
dsl.errors_crcp_p_far=0
dsl.power_mode_num=0
dsl.power_mode_s="L0 - Synchronized"
dsl.latency_num_down="8.0 ms"
dsl.latency_num_up="0.0 ms"
dsl.latency_s_down="Interleave"
dsl.latency_s_up="Fast"
dsl.data_rate_down=55000000
dsl.data_rate_up=9995000
dsl.data_rate_down_s="55.000 Mb"
dsl.data_rate_up_s="9.995 Mb"
dsl.line_attenuation_down="11.8"
dsl.line_attenuation_up="10.6"
dsl.noise_margin_down="7.6"
dsl.noise_margin_up="12.5"
dsl.signal_attenuation_down="12.1"
dsl.signal_attenuation_up="10.7"
dsl.actatp_down="-1.5"
dsl.actatp_up="-1.7"
dsl.max_data_rate_down=71224872
dsl.max_data_rate_up=19389375
dsl.max_data_rate_down_s="71.224 Mb"
dsl.max_data_rate_up_s="19.389 Mb"
dsl.line_uptime=347
dsl.line_uptime_s="5m 47s"
Thank you 🙂
Tags (2)
1 REPLY 1
Message 2 of 2
Re: Line 'stuck' at 55 down 9 up.
Your line has been provisioned as Fibre1 rather than Fibre2. Call customer services and point out their error.
