Message 1 of 4
MyBT app reporting BT Smart Hub poor connection
Can anyone please explain exactly what this issue is and how it can be rectified.
3 REPLIES 3
Message 2 of 4
Re: MyBT app reporting BT Smart Hub poor connection
are you having connection problems? drops in internet or hub resets?
Message 3 of 4
Yes.
Message 4 of 4
have you tried anything to fix problem - if have landline phone not on DV tried 17070 option 2 to check for line noise or connected direct to test socket and see if that helps or have you tried something else
