Message 1 of 7
Need help to get a fibre to premises instal
Daughters house has fibre port at the pavement or at least fibre in the street
they are currently on virgin ( just been corrected they have a Vodafone service at the moment ) and want to move to BT
other houses in street are getting front gardens dug up to instal the BT fibre to the house but my daughter has been told they cant have it as too expensive  to dig up their front this doesn't make any sense to me
how can we get a survey , if needed I could assist with digging a trench for BT  to make it easier
Would even lay the duct for BT if it was provided
only talking of 15 metres  of drive way they could have the trench dug up the side
6 REPLIES 6
Message 2 of 7
Re: Need help to get a fibre to premises instal
can you enter your daughter's address and post results including all the notes which will show what is available and if dig is needed
https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
Message 3 of 7
Message 4 of 7
Who told your daughter they couldn't have FTTP?
Message 5 of 7
I assume by posting on the forum that you intend to us BT as the ISP.  if so did you try and place an order with BT
Message 6 of 7
Aah full story only now becoming  clear
sorry  now hearing full story
so looks like they tried to go to vodafone from virgin
vodafone who mustbe ? Using openreach declined saying an fttp install would be too expensive  so they declined
I have now suggested they just go direct with BT ( I would say that as BT pay my pension )
so hopefully BT will run the fttp in
thanks for your assistance !
Message 7 of 7
Vodafone sent out a Bt openreach surveyor who took photos and said that BT would not install fttp as distance too far and it exceeded the £1000 limit they said same refusal would apply
 even if they were applying for BT/ EE broadband
If this DP is too far on this side of road could they not use the DP and fibre that extends closer to their property on other side which is a culdesac  and the house is at the end
See the photos we were provided with ?
They are now applying for BT broadband but concerned this too will be rejected for same reason Openreach surveyor mentioned
Surveyors report :-
“Buried estate new duct required from house around edge of driveway 28 in soft and and then to box 25m hard marked up with grey paint cable coiled up at CBT”
this is the surveyors photo of the coiled cable he mentioned
could openreach access the premesis from the opposite side of the street as shown below ?
