Message 1 of 5
New BT Router
Hi enginner has been out today and set up or checked new fibre 100 connection i cannot connect to any wifi device?
Can you help?
Mark
4 REPLIES 4
Message 2 of 5
Re: New BT Router
Has the new Hub replaced a previous one or another 3rd party router? if so you'll need to connect to it on each device using the details on the back of the new SmartHub router.
Helpful guide for basic method to connect on various device types e.g. Windows Andorid tablets etc can be found here - https://www.bt.com/help/broadband/getting-set-up/how-to-set-up/connect-devices
Message 3 of 5
Re: New BT Router
Can you connect to wired devices?
Message 4 of 5
Re: New BT Router
hi thank you i found out why, bt had put 2 different plastic cards or whatever they are called in the back of the router one was not the correct details from another hub? i have now tried the card underneath and they are the correct details!!!
Message 5 of 5
Re: New BT Router
Hi thank you fro the reply i have found the answer!!!
