Message 1 of 5
New FTTP install - speed well below guarantee
Hi,
Just had Full Fibre (900Mbps) installed but getting only 250 Mbps on speedtest (device ethernet attached to Hub). Is this normal for a new install and does the speed eventually ramp up? Thanks for any input.
4 REPLIES 4
Message 2 of 5
Re: New FTTP install - speed well below guarantee
Speed should be 900 immediately.
Is the attached machine (network card) up to date/spec?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
Message 3 of 5
Are you measuring the speed on a wireless or wired device?  A wireless device will never attain the full speed of the line.
Also I think it takes 48 hours or so for the line to balance..
Message 4 of 5
The OP does state ethernet connected device.
FTTP speed should be immediate, no need for the line to balance.
Message 5 of 5
Thanks for the response all.
I am measuring from a iMac (10gbps network), directly attached into hub2 (ethernet). It is a fresh install so will give it another 24 hours to settle and will report back.
Thanks,
