Message 1 of 3
New Fibre Install ?
Hello i just had a new fibre install yesterday fibre is running fine no issues if you take a look at the picture can you see the wire shouldn't that be coveredfibre.jpg by the grey box ??
2 REPLIES 2
Message 2 of 3
Re: New Fibre Install ?
In a word. No.
Message 3 of 3
The fact that the cable jacket is black means it’s an external grade cable and won’t suffer from degradation from the elements etc , if someone was ( for example) worried about a vandal cutting that tiny exposed bit of cable , a determined vandal could simply smash the CSP block off the wall anyway , so it’s really no less ‘safe’ than an installation where not even a tiny part of cable was exposed .
TBH , that is a very tidy install , any ‘complaints’ about it are not really justified.
