I'm currently looking at changing fibre providers, for some reason everytime I enter my postcode or telephone number with other providers they come back with being unable to provider a service even though I currently have fibre broadband with BT.
Solved! Go to Solution.
Are you in a new build? if so you may find this helpful
https://www.openreach.com/help-and-support/problems-and-appointments/broadband-in-new-build-homes
I don't live in a new build.
It is possible that if you have FTTC that your cabinet is full with a waiting list which would explain why no connections are available
Enter your address not phone number a d post results.
https://www.broadbandchecker.btwholesale.com/#/adsl
So from the result you must currently have FTTP. It may be that other ISPs are not providing FTTP in your area.
But it says WBC FTTP is avaliable.
Which is what I currently have.
Exactly. Not every ISP offers FTTP.
That shows FTTP is available at your address via an Openreach provider yes
