Message 3 of 7
Noise margin
Can someone tell me why my noise margin has changed alot .since firmware update
6 REPLIES 6
Message 1 of 7
Noise margin
can someone help me out .I had new firmware update but it's changed my noise
Message 2 of 7
Re: Noise margin
Spoiler
Message 4 of 7
Re: Noise margin
noise margin will fluctuate due to line conditions but as you are on max 80/20mb connection on fibre 2 your noise margin is good and nothing to be concerned about
please stop posting on different boards as that just causes confusion
Message 5 of 7
Re: Noise margin
Thanks you very much 👍
Message 6 of 7
Re: Noise margin
So u don't think I got nothing to worry about .my noise margin as always bean 15.4.6.4.now its down to 7.4 that's a big drop
Message 7 of 7
Re: Noise margin
It doesn't matter a jot what your noise margin is, you are getting the maximum speed possible.
