Message 1 of 10
DLM not lowering Noise margin
Hi All,
Quick question, I have left my router on for almost a week after going live on 1st July, I would of expected DLM to of made changes to my line, How long does it normally take for it to kick in and G.INP to activate?
Stats Below, I have achieved 73/74Meg on my line before.
Product code:Hub
Serial number:+091298+2203049317
Firmware version:v0.33.00.12274-BT
Firmware updated:Fri Jul 1 00:12:24 2022
Board version:R01
GUI version:1.74 12_11_2020
DSL uptime:6 days,12 Hours01 Mins11 Secs
Data rate:19.767 Mbps / 63.35 Mbps
Maximum data rate:19.759 Mbps / 63.501 Mbps
Full Fibre (FTTP) Mode:On
Noise margin:5.7 / 5.9
Line attenuation:9.9 / 16.2
Signal attenuation:9.9 / 18.3
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:9.4 GB Uploaded / 74.1 GB Downloaded
Broadband username:[email protected]
Public Wi-fi status:Activated
2.4 GHz wireless network name:BT-7XCW3T
2.4 GHz wireless channel:Smart (Channel 1)
5 GHz wireless network name:BT-7XCW3T
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:18:58:80:01:92:66
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
9 REPLIES 9
Message 2 of 10
Re: DLM not lowering Noise margin
Can take 7/10 days for DLM to activate G.INP  assuming you are on a Huawei cabinet
In hub stats FTTP MODE should be 'off'
Message 3 of 10
Which exchange and cabinet are you connected to. If you are connected to an ECI cabinet, you won't benefit from either G.Inp or 3dB noise margin and are currently getting the best speed possible if that is the case.
Message 4 of 10
@licquorice Huawei cab. Midhurst Cab 12, Previously have had 3db in past on my old account.
@imjolly It’s now off had to sadly reboot the router ugh.. why was that on.. start again.. ugh. It’s not dropped down to 62 meg goodie! Ugh..
Message 5 of 10
Still no change? Confused would of thought it would of lowered by now..
Product code:Hub
Board version:R01
DSL uptime:12 days,07 Hours09 Mins12 Secs
Data rate:19.346 Mbps / 62.215 Mbps
Maximum data rate:19.346 Mbps / 64.247 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:6.0 / 6.4
Line attenuation:10.0 / 16.3
Signal attenuation:10.0 / 18.2
VLAN id:101
Data sent / received:13.2 GB Uploaded / 111.6 GB Downloaded
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless channel:Smart (Channel36)
Message 6 of 10
Just checked and you are on Huawei cab.  G.INP is automatic and controlled by the DLM so there is nothing anyone can do to and you just have to stay connected and wait
Message 7 of 10
Thanks for checking! I will just leave it be. Its rock solid stable..
Thanks! 🙂
Message 8 of 10
Day 16
Product code:Hub
Board version:R01
DSL uptime:16 days,01 Hours29 Mins41 Secs
Maximum data rate:19.346 Mbps / 64.216 Mbps
VLAN id:101
Data sent / received:17.1 GB Uploaded / 147.0 GB Downloaded
Message 9 of 10
as I posted before the application of G.INP is automatic and controlled by the DLM - there is no manual intervention
Message 10 of 10
Hi All,
I’ve left my router alone for 6 weeks and still no change? Any ideas why I’m stuck with the same speeds? I can definitely sync faster? I’ve had 74 meg on the same line back in Feb. It’s just stayed on 63 meg..
anyone?
