Message 11 of 13
Re: Online gaming issues
If your phone is used as a hot spot then the Roku is using your mobile data to serve its internet right?
So you have stopped the Roku using the BT internet, it will leverage your phones 4G/5G instead, this indeed would stop TV steaming effecting your gaming.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 12 of 13
I thought the same, I turned off the WiFi connection on my phone and the roku ate my data, I turned it back on and it used the Internet off my router, it's bizarre and it works and I'm baffled but happy.
Message 13 of 13
Online gaming issues can stem from server problems
