Message 1 of 10
Openreach FTTP database incorrect
Hello,
I'm after a bit of help / advise. I'm trying to get my Mum's broadband upgraded to FTTP but hitting an issue with the Openreach database.
My mums billing address references the house name, when you check the Openreach FTTP checker using the house name it says FTTP isn't available. If you use the checker and use the house number it says it is available.
I've reached out to BT Openreach via their online form and explained all of this and they helpfully replied and just said it was available and that I just need to place an order, but I can't...
If it was just broadband I'd just place a new order using the other address but we'd like to retain the existing landline number so that means an upgrade.
Just feel like I'm going around in circles and not making any progress.
Can anyone advise how to get around this issue?
9 REPLIES 9
Anonymous
Not applicable
Message 2 of 10
Re: Openreach FTTP database incorrect
Is the error the same on RM's database? If not try this form:
https://www.openreach.com/forms/fibre-broadband-availability---customer-form
Message 3 of 10
That link is the form I filled out.
I gave the house name and explained what the issue was and they just said it was available and to place an order.
I've tried replying to the email they sent but don't know if they monitor replies.
I'm through at my Mum on Saturday, I might try phoning them and see if they can do anything with the billing address like change it to the one where FTTP is available and attack it that way.
Anonymous
Not applicable
Message 4 of 10
You didn't answer the RM question.
Message 5 of 10
I've just checked the post code.
Only the house number shows up not the house name on the Royal Mail address finder.
Message 6 of 10
Is the house name ‘ official ‘ , so all the relevant authorities refer to the house name ( so council tax , utilities, Royal Mail etc all show the house name ) if the house name is ‘unofficial’  and something done without notifying the relevant bodies ( like calling a house Dunroaming as a laugh ) then getting an upgrade may be tricky …if your BT bill references the unofficial house name and the correct house number entry also exists, you would probably need an ORDI ( Openreach data integrity ) to try to remove your unofficial house name entry and associated your BT bill with the official house number address .
Alternatively you order FTTP ( with no telephony ) to the house number address on file , and when it’s in and working , port the number to a VoIP provider ( and get the appropriate ATA equipment ) , this closes the account with the house name on it  , it’s not as convenient as an upgrade but should work .
Anonymous
Not applicable
Message 7 of 10
Historically trying to find someone in a BT call centre who even knew what an ORDI is was problematic. The forum Moderators have assisted in the past, but as they are no more that avenue is probably closed.
The notion of removing the made up name from the BT account may help, but even if it does, it will probably take some time for that to filter through to OR. But certainly worth a try. Maybe in tandem raise another form with OR specifically referencing ORDI, & that the two entries need to be merged. Also mention that the house name doesn't appear on the RM database. Just maybe, using a term that they recognise will get you through to someone who can actually help.
Might also be worth looking up the UPRN for the address & see if that's duplicated, & include those details to OR.
Message 8 of 10
Will it not let you add and keep the phone number if you place the FTTP order against the house number rather than try to sort out the issue with the name?
Message 9 of 10
Unfortunately not, the moment you enter the number it knows its associated with a BT account and makes you sign in. The address on the account then says it not available.
I'll go back to OR and see if they can do anything.
I guess I could use an alternative provider and just order it to the correct house number and request a transfer of the landline number. I'd have preferred to stay with BT but if it drags on much longer I'll just do that.
Thanks for all the advice.
Message 10 of 10
Have you tried calling BT rather than try to do it all online? Explain the issue and see if they may be able to process it as a home move instead.
It may be that you swap to EE (all BT residential customers will do this eventually).
