Message 1 of 4
Openreach ONT not booting
Internet doesn't work and I see all 4 port lights flashing. What's wrong?
Short Video
3 REPLIES 3
Message 2 of 4
Re: Openreach ONT not booting
Have you had any lightning?
Turn it off for 2 minutes.
If that doesn’t fix it there should be a pin reset button, hold that in until it reboots.
If it’s still not working ring your provider as it will likely need changing.
Message 3 of 4
I've done all those steps with no luck. Thank you
Message 4 of 4
Installed and replaced hundreds of them 4+2 ONT’s over the years.
Came across that fault quite often, in fact it was so common we had a nickname for it. Disco Lights of Death or something like that.
Basically yeah, it’s Ducking Ducked Ducked and will need to be replaced.
Good luck reporting a fault through BT.
