Message 1 of 6
Openreach call?
I received an automated call from Openreach on an 07701 number earlier. Unfortunately I only got as far as 'This is Openreach...' before I needed to ditch the call due to someone urgently needing my attention. Presumably it is related to my FTTP installation tomorrow.
Does anyone know what they say in this call?
Ringing the number back just says you have dialled an incorrect number.
5 REPLIES 5
Message 2 of 6
Re: Openreach call?
Most likely just to remind you of the Appointment Date/Slot.
Message 3 of 6
Re: Openreach call?
BT have done this multiple times already so why do Openreach do it as well?
Message 4 of 6
Re: Openreach call?
Because Openreach are the ones actually doing the work.
Message 5 of 6
Re: Openreach call?
I had several updates from both BT and OR for a OR visit.
Message 6 of 6
Re: Openreach call?
Because they can’t trust CP’s to do it right maybe?
