Message 1 of 4
Orange and white
ok so have a BT box I want to move to a different room and have enough cable to cut it where it is to go to the new room I want it. I have open the box up and see there are only two cables connecting it orange and white. White into the (A) and the orange being in the (B) so guessing I would cut the cable and connect the same back up and will work ????
Also is this a old way the orange and white cable is there anything newer for faster speeds ??? Or are orange and white cable suffice enough or can this be upgraded?
3 REPLIES 3
Message 2 of 4
Re: Orange and white
No, its normal external grade cable colour scheme. The type of cable will make absolutely zero difference to your speed.
I strongly recommend that you don't cut and join the cable as it belongs to Openreach and if a fault developed you might get an unexpected bill. Entirely up to you.
Message 3 of 4
Hay no I don't plan on patching a cable on to it it will be that cable I will just be moving it from downstairs to upstairs on the same cable but I will have to cut it to get it out my window and will just us the same cable in its new position upstairs ☺️
So is that cable good enough for fast speeds?? Or would it be worth phoning BT and see if they do some upgrade?
Anonymous
Not applicable
Message 4 of 4
Depends what you mean by "fast speeds". The standard copper cable will be good enough for FTTC & assuming it isn't faulty, the speed will be largely determined by the distance to the street cabinet. Have you checked to see what services/speeds are available?
BT Broadband Checker
If FTTP is available then that would be provided by a new fibre cable.
