Message 1 of 3
Orange solid light bt smart hub 2
Hi,
been connected fine to the internet, just came home yesterday to a flashing purple light, decided to forget it as it was late, this morning it’s now a solid orange.
connected to main router in my house - LOS- red light
power- green
PON - no light
LAN - green
can anyone help, tried resetting etc.
2 REPLIES 2
Message 2 of 3
Re: Orange solid light bt smart hub 2
Red LOS light means you have lost the optical signal. You need to report the fault 0800 587 4787
Anonymous
Not applicable
Message 3 of 3
Might be worth checking that the optical cable hasn't become dislodged from the ONT.
