Message 11 of 20
Re: Possible error on line or put into banded profile. How to fix?
@imjolly I'm afraid I'm not sure what you mean by use text socket.
Message 12 of 20
The mods here no longer have account access unfortunately.
I'm afraid you need to persevere with customer services, they should be able to see you have a line fault. Don't tell them you have a connection.
Message 13 of 20
If you remove the faceplate of the master socket, there will be a test socket behind it.
Message 14 of 20
I assume your router i s connected to the mastersocket so if you remove the front plate you should see the test socket behind. You will need an old style filter to plug in to test socket then connect routertest socket.jpg
Message 15 of 20
Ok understand now with test socket. Thought text was something else to do with old analogue line or something.
Engineers no longer help on this forum? That's rubbish, was only thing that I kept telling myself was helpful about BT, a way to get through to someone that could actually help. Now that's gone will somehow have to get problem fixed and then bin BT off I think. Not worth it for price and lack of support.
Thanks for the help. All round more depressing news than I thought at start of evening.
Message 16 of 20
@imjolly thanks for clarification. Unfortunately I don't have a filter anymore.
Surprised if it is master socket which has gone wrong. Stuck behind a Welsh dresser and nothing has touched it in 4 years since last time there was a problem. I'm assuming if it's master socket playing up I'm liable for costs of engineer visit etc as cabling broken inside my property? Even though I've done nothing to it and last person to touch it was BT engineer who installed it last time I had a problem?
Message 17 of 20
Just an update on this. Found a filter in the cupboard and things lot better using test socket.
Router stats are:
So does this mean problem is with my internal wiring or faceplate on master socket or something else.  Tempted to just leave it stuck into test socket.
Message 18 of 20
Yep, the problem lies within your internal wiring or the master socket. If the fronplate of your master socket just clips on rather than screwed it is often the source of the problem. Try  replacing the front plate and see if simply removing and replacing it has resolved the problem. Otherwise there is no problem with leaving your router connected to the test socket other than the aesthetics.
Message 19 of 20
Thanks for the clarification.
I'll try another faceplate at some point. No problem with the aesthetics, the master socket is stuck behind a Welsh dresser full of books.  That was why I was reluctant to investigate problem to start with, it weights a 100 tonne and is a p.i.a to move.
Message 20 of 20
If you look at your non BT router stats before the ‘fix’ and after  (that in itself is a reason why support may be somewhat lacking , if you chose to use your own router rather that the BT supplied one, BT only supports their own equipment ) ..your line attenuation was massive when you first posted the router stats (50+dB ) and now around 10bB , so you obviously fixed the issue yourself.
