Message 1 of 3
Project Stratum
The FTTP roll-out is coming to the local area circa October 2022.  Will I have an immediate  choice of fibre broadband providers or will Fibrus be the only  immediate choice for me?  I am lead to believe that BT can only start offering their fibre packages when the Project Stratum fibre roll-out has been completed, ie 2024/25.  Is this the case?
Thank you.
2 REPLIES 2
Message 2 of 3
Re: Project Stratum
Looking at Project Stratum, Fibrus Networks Ltd and https://hyperfastni.com/suppliers. Fibrus Networks is an alternative full fibre network provider. BT uses Openreach network and therefore you you won't be able to use BT as your broadband provider over the Fibrus network.
Message 3 of 3
Re: Project Stratum
Thanks for the clarification with this matter. Much appreciated.
