Message 1 of 5
If I upgrade to Halo 3 from Fibre 1, can I connect more devices without loosing my speed?
Just now when all the kids are on their devices, our new Sky Glass TV starts freezing.
4 REPLIES 4
Message 2 of 5
Re: Halo 3
Halo 3 is a benefits package, it has nothing to do with your broadband connection or speed.
Message 3 of 5
Re: Halo 3
If the line supports it, the OP would of had a speed increase, Fibre 1 is 55/10 SLT, Halo plans come with the 80/20 SLT
Message 4 of 5
Re: Halo 3
Where is that documented.
Not here https://www.bt.com/halo/terms
Or here https://www.bt.com/help/broadband/learn-about-broadband/bt-halo/what-is-bt-halo-and-how-can-i-get-it...
Message 5 of 5
Re: Halo 3
Not sure, I just tried to sign up for Halo as a new customer, the speed estimate should match Fibre 2 but Halo isn't showing as an option, I'd have to try other postcodes later.
