Message 1 of 6
Property information incorrect
Hi  @StuartH
I have seen a post where you offered to help sort a similar issue. How do I get the database holding information on available broadband connection types for a property updated ?
I am asking this question on behave of my farther, as few months ago Openreach engineers installed fibre with the termination points to the telegraph pole on his property and informed him that he and his neighbours would now be able to get FTTP.
When I check his address FTTP is not available but checking his holiday cottage address which is physical part of the same build FTTP is available.
It looks like the information for his property was not updated, can this be corrected so he is able to order FTTP.
5 REPLIES 5
Message 2 of 6
Re: Property information incorrect
Hi @TPT
I believe speaking to BT customer sevices who can send a form off to Openreach to get an update on FTTP avaliability and updating the database is the way to go on this one, I am also currently in this process as Openreach say we can have FTTP but no packages avaliable on the BT website.
Josh
Message 3 of 6
If BT customer then enter phone number and post results
Is your address correct on royal mail database?
Message 4 of 6
Hi Josh,
Thanks for the response.
I have called BT customer service but they are unable to get the information updated as my farther is with Plusnet. They suggested for me to contact Openreach directly.
Tim
Message 5 of 6
you need to contact plusnet and get them to raise an ORDI with openreach to get data updated  openreach direct will not help
as plusnet customer there is nothing BT can do to help
Message 6 of 6
The postal address is correct.
Using the  btwholesale checking site I had interesting results, if I check using the phone number FTTP is available but if I check using the address FTTP is not available.
When I contacted BT to see if they could supply FTTP  I was told that FTTP was not available and they could only check by the address not by the phone number.
